Topic: time for upgrade (Read 1656 times) previous topic - next topic
time for upgrade
So my thoughts were right!! figured my turbo was gone due to smoke clouds behind me when i shifted and power was also down. Took the intercooler and vam hose off the turbo and oil every where, shaft play front to back is about a 1/4" play...!! Guess its time for my completely rebuilt T3 from turbonetics.:burnout:
time for upgrade
Wow!  That wasn't expected.  At least it gives you an excuse for new parts. :) You'll like the turbo upgrade...  What trim are you looking at?  0.48? 0.63?  You may want to upgrade to a higher flow fuel pump with your turbo upgrade... :burnout:
Daniel
time for upgrade
I like exuses to upgrade lol
time for upgrade
Me, too, as long as I can afford the excuse... :)
time for upgrade
Quote from: BornInAFord;416349
Daniel
How many pounds you think I would be safe with until i get a new(255) pump in? have a new adj. regulator.......
time for upgrade
Your pump cant handle too much more. Depending on what size turbo you get. I wouldn't go passed 15-16lbs to be safe.
