Topic: Fuel pressure regulator. (Read 1821 times) previous topic - next topic
I've been trying to find an answer on this forum and on the internet without any luck. From what I have read the pressure regulator on my "86" stock 5.0 engine was to be set at 39 psi. Now that I have an "87" Mustang 5.0 HO engine with a stage #1 cam, dual exhaust, and MSD distributor, how do I know what my fuel pressure regulator should be set at? I found an adjustable BBK regulator and gauge that mounts to the rail. Now I need to know how to set it up properly. Thanks!
Just set it to 40. Its really not that critical.
Quote from: bryan163;415992
That's exactly where it's at. Thanks!
With or without vacuum connected ??????????????????????????? Makes a big difference !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
43 with no VACUUM
Quote from: TOM Renzo;415999
43 with no VACUUM
All the Ford literature I've read on the '80s and early '90s SEFI systems state 39 psi, never have I seen 43...
the CFI FPR's are factory adjustable, just remove the top little freeze plug or the aftermarket replacement types with a plastic top to reveal the allen head adjustment.
you just cut off the mounting area of the FPR on a CFI and keep that part along with the FPR and you saved a lot of money.
they do not however take a vac line but thier design is very reliable.
Quote from: jcassity;416042
That's good to know. Thanks!
