Topic: Headlight update (Read 1055 times) previous topic - next topic
Headlight update
I couldn't find the orig thread, but was a talk of sanding and putting the varnish on headlights, well here is a before and after
And my car has been sitting outside for about 6 months since and is still that clear.
Headlight update
awsome ,,
all in my diy link  below  but here is the thread
headlamp rework and remirror the insides, clear coat the outter lense
 http://www.foxtbirdcougarforums.com/...ior&highlight=
and the results
results of my headlamp modification
 http://www.foxtbirdcougarforums.com/...ion&highlight=
and a buncha other light stuff and goodies
Relay adds to remove heat from headlamp and ignition switch
 http://www.foxtbirdcougarforums.com/...d-Marker-lamps
HIGH BEAM *with * low beams on modification ~just an easy jumper wire. ((applicable to those with auto lamps only))
 http://www.foxtbirdcougarforums.com/...054#post408054
headlamp resources
 cougs & bird headlamps match up with 89>94 linc continental, per Vinnie- he doesnt see linc headlamps as dull as coug or birds
Headlamp HID stuff > thanks THEFOEYOUKNOW
 http://www.theretrofitsource.com/pro...roducts_id=227
 http://www.jcwhitney.com/headlight-c...2824j1s17.jcwx
 HID mod> Thanks TbirdX3
 http://www.foxtbirdcougarforums.com/...%29&highlight=
Convert your not so accurate amp meter to a volt meter easily
 http://www.foxtbirdcougarforums.com/...&daysprune=100
Cool down that big resistor on the back of your buttstuffog instrument cluster.
 This also applies to those with digital clusters except the resistor is smaller.
