Topic: DuraKool Relays and switches ect Swiss Made (Read 1137 times) previous topic - next topic
great resource,
i found this company brand in one of my 150kw Cat generators, reserached the source.
im impressed, switching my source vendor to this company.
should be a great source for all you project guys..
these go way up in ampacity as well so keep that in mind.
the relays i have now on my IGN and ACCY ckts get suspiciously warm ,, sorta to the Hot side so i may be changing them all out.
here is the link you can shop them at,, Tom Renzo, Foe and all....... you may want to check this out.
http://www.newark.com/durakool
here is one of my cheat sheets i drew up that summarizes my customers 106 page alarm monitoring requriements.
I usually stuff this among other quick reference single page drawings into my engineering packages / scopes of work before i get contractor bids.
The magintued of alarms i have to capture is vast and some equipment doesnt have dry contacts to monitor so i have to get the manuf approval first so there is no warranty issue , then figure out how to catch all the alarm points my customer wants to monitor.  The biggest headache is getting dry contact alarm points out of an HVAC unit that only has one common "unit fail" relay.
