Topic: too much air? (Read 7389 times) previous topic - next topic
too much air?
what is the mk vii ecu do u need i have an 88 tbird with a so 5.0
too much air?
Quote from: V8Demon;425241
  Did Scott ever find the reason for this phenomena before anything else occurred?
we never figured it out.. the fuel pres was solid 39psi in the garage..
while in motion it never went below 34psi between first and second.... this told me all i needed to see.
anyway,, its a totally different engine now..... with one remaining issue we need to look at next week when he comes home.  we believe an exhaust valve is not seating all the way after doing our leak down test.
too much air?
Quote from: jcassity;426066
Fuel pressure should always maintain 39 PSI at WOT... That is what's important, if it's anything less you're running lean...
