Topic: 12v power junction blocks (Read 3824 times) previous topic - next topic
what are you guys using for junction blocks up front when you relocate the battery to the rear, any pics??
no pics
my recommendations=
either of these would do ok
"think" insulated and "isolated" when mounting as well as "covered or protected"
hope this helps....
you may find the turnkey solution at your local "AC" supply house like grainger, local electrical store or even perhaps your auto parts box store.
the first pic may be best, the second pic would be applicable to a two hole lug which would put a + cable in and another + cable on top going out to the trunk, same pattern for the second connection point.
i suggest 1/0 flex or min 4awg flex RHH/RHW
Why do you need a junction BOX. It is not necessary at all. Terminate it on the solenoid on the fender  or on  starter depending on which starter you have.
Quote from: TOM Renzo;414655
When I originally relocated my battery, I used the starter solenoid on the driver side fender. The car is now a drag car and I completely re-wired the car and now use an old stereo mega fuse holder as a connection point for the power and ground( one side is for the power and the other side is for the ground) hook ups, and I also use a through the firewall lug stud set up.
Donnie
10 Second NA TBird
Fredericksburg Va
I moved the solenoid and don't want run all stuff to it, want to make a spot in the inner finder area, found some junction studs
Where did you move the solenoid ??? I see them moved to the trunk  and just wonder why one would do this. Other than complicating the battery move for no reason.
Below is the relay for the Midnighter. I moved it inside the fender well with all the other wires to tuck the wiring. I hate ugly wires under the hood. You can see the link extender i made to allow the battery cable from the trunk to be connected and this works great. I have been doing it for years this way. Simple clean and proven method. just me
did not move to trunck, i moved to back of engine bay, where the computer harness comes out.  I did this because I did not want to have to get up in the inner finder if it went bad.  but the engine bay is all smoothed out, so I am trying to keep as clean as possible.  You have a good idea there.
XXX
I got two of these: http://www.ebay.com/itm/NEW-12-v-volt-auto-insulated-battery-ring-lug-terminal-junction-block-power-post-/290653728418
on your fuse block, pull it back off and put a non conductive barrier between it and the body.
flip it over and you can see the primary & secondary fuse terminals are open and debris could get in there and short to the body.
nice work so far
Thank you for advice, I have a rupper mat I will cut up to fit.
just thougth id peak your curiosity to see what i meant, now you know your build is less likely to have an issue on the mounting at least.
one other thing,, the block you have made by buss i assume is 100A rated, but the main buss coming in is only 80 *exact ampacity* rated.
Buss derated by 20% in thier design for a higher nameplate listing which is allowable under UL.
also, becareful how tight you have your mounting bolts.  i took min apart to figure out why the top terminal cover bowed like that and fixed the factory flaw with nylon washers inside it to shim up the difficient area that needed more plastic.
nice work though,, it would be nice if that fuse block accpeted two hole lugs for more surface area contact but oh well.
very nice wiring by the way, neat and protected.
check in on your heat shrink one day though, after a few engine runs dont be surprised if the tubing isnt strining futher,, LOL,, made that mistake one day.
these are what i used with hard top seabring relays
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
