Topic: gauge lights (Read 1748 times) previous topic - next topic
gauge lights
Morning Guys,
Could some one please tell me which wire to tap into to connect pillar gauges lights to? and where located? would like to be able to adjust with dimmer.....
Thanks, Joe
gauge lights
Oh yea, this is for an 88 turbo coupe
gauge lights
Circuit 19 Lt. Blue/Red stripe coming from the headlight switch is the instrument illumination, controlled by the dimmer. Easiest place to tap into would be the pigtail for the bulb that lights up the headlight / dimmer / autolamp panel.
gauge lights
Thanks guys....
