Topic: Brakes (Read 1673 times) previous topic - next topic
Brakes
Need help with a brake problem on my buddys 86 Cougar w/3.8L
He has put two master cylinders on it and after a few weeks of driving the pedal starts getting soft again. Just wondering what some of your thoughts might be on the problem. Thanks
:birdsmily: Nate Wenck
Carroll IA
nwenck@msn.com
07 Suzuki Boulevard C50T
2003 Ford F-150 Supercrew
Re: Brakes
could easily be a slow leak in the brake lines. Check the brake booster as well. could be rotted hoses too.
Re: Brakes
Is there a special way to checkthe brake booster without jusyt replacing, because there a little on the expensive side.
Carroll IA
nwenck@msn.com
Re: Brakes
check the brake line that come's off the calipers .the small rubber line's get old and they may look good on the out side but the shrink in the inside
Re: Brakes
Check the rear brake adjusters, both to make sure they work and to make sure they're properly installed (left and right adjusters are unique). Also check the caliper sliders, and the front wheel bearings - a wobbling rotor will push the caliper pistons back in their bores and cause a soft pedal.
