Topic: seat belt latch spring? (Read 1883 times) previous topic - next topic
Is there any way to fix my seatbelt latch, or is it just one of those find a pass side one in a junkyard and put it on?  Mine holds most of the time if you hold it vertical and then yank it tight, it'll usually stay, but I really need to replace/fix it.
What color do you need? I probably have a good raven colored one that I could ship to you for $25.
Yeah I do need a raven one.
I know that I have at least one extra good one if you are interested.
Yeah, I am.  Have a paypal?  At least once you find it?
Just a clarification? Are you wanting the drivers side or passenger side? I have both.
The one in my Thunderbird did the same thing. I ended up getting a rear seatbelt latch and using the spring in the driver's latch. The buckles just pop apart with a screw driver so the spring swap is easy.
