Topic: V6 to turbo 4 (Read 3254 times) previous topic - next topic
V6 to turbo 4
i wondering if it would be possible to switch out my 6 for a turbo 4 and how difficult it would be. Also when switching out a motor do i need the same computer i use for the or one thats made for that specific motor?
Re: V6 to turbo 4
what year is your V6?
its not *very* hard, but youll still have some work to do to get it to work
youll need the wiring harness, and computer, along with the engine, and motor mounts
It's Gumby's fault.
Re: V6 to turbo 4
figures i  would need all that junk lol
Re: V6 to turbo 4
Plus you'll need the 4cyl tranny as all but the C4 are different than the v6/v8 versions. Even with a C4 you would need the 4cyl bellhousing and they are getting very hard to find.
Re: V6 to turbo 4
its an 1985 with about 77 thousand miles on it. so it would be a better idea to swap it out with an 8 then?
what about the turbo coups what motor to they have seeing how ive never seen one up close,
Re: V6 to turbo 4
turbo coupes have the turbo inline 4 as well as the 1984 to 1986 XR7's. It would prolly be easier to pick up a whole car and gut it for parts. Then send it off to the junk yard. Just check coolcats.net in the tech section to see what kinds of things that you can use/ do.
Re: V6 to turbo 4
Quote from: UnForGiveN
It would be the same amount of work to swap in a 2.3T as it would a 5.0.....just figure out what you want to do.....
The TurboCoupes have the 2.3T 4 cyl....
Re: V6 to turbo 4
'88 Turbo Coupe intercooled 2.3... This is my red 5 speed TCs engine bay...
All '87-'88s had the intercooler, '83-'86 did not...
V6 to turbo 4
Will the '88 TC engine harness plug into the body harness on an '88 V6 car?
I've got the complete car to take all that I'd need off of....
The donor and the recipient car are both '88.
I know it sounds kinda bass-ackward to go from V6 to a 2.3, but I can't seem to find the V8 I want, and this engine is very likely a runner...
