Topic: Front clip replacement? (Read 2335 times) previous topic - next topic
Ive just discovered ive been driving around with my front clip frame rails literally rotted to pieces.  Since I know nothing about bodywork/fabrication, I was originally going to leave it until i got the whole car disassembled, and have a professional refab it, but now its so bad i fear the car with break in two if i keep driving it.  Has anyone ever replaced a front clip before, or done a fix to rotted frame rails?
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 3.8 V6 - Rescue
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 5.0 V8 - Survivor
yes
what did you do, fabricate a fix, or replace the frame?
I think there's also a guy on FEP who fabricates the front subframes for fox bodies
YES ALL THE TIME!!
Spark machine plenty of wire assortment of various angle iron and plating. A pizza every 4 hours and a beverage of your choice.
the worst thing I had to try to fix... I also had to replace part of the firewall where the frame was once attached, along with the lower part of the strut towers...
I also had to clip the rad support... if your rails are rotted, the support is probably cooked too
if you are repairing.. dont forget to make new crush sleeves for the kmember
and if your going that far... may as well box and weld all the holes closed, along with all the seams
Nice hole weld up a clean engine bay is where it is at. Plenty of grinding and filling but that is worth it when you POP THE HOOD!!!
