Topic: Lamp out warning module - Where is it? (Read 1674 times) previous topic - next topic
Hi, I need to find the lamp out warning module. EVTM says, that it is "Behind extreme RH side of I/P". That tells me nothing. Is it behind the glovebox, or somewhere else? How does it look like? From the wiring diagram, it is probably a box with two connectors (C239 and C240).
I want to find it, because I need to find a reason, why the "rear lamp out" warning is illuminated when I turn on the lamps, even if all bulbs are OK and correct type.
Thanks
Above the glove box opening.
What's the color and size of that box? I saw two boxes behind the glove box, one is on the right and one on the left. Between these boxes is A/C outlet with actuator.
Can you send me on exact spot, please?
Diagram added to post 2
