Topic: '86 Cougar power window guide question (Read 3153 times) previous topic - next topic
Hello - new guy here. Looks like plenty of info here, but I can't find what I'm looking for.
On my '86 Cougar with power windows, when I roll the driver's side window down, it drops forward a bit. Then, when I roll it back up, if I don't grab the window and pull it toward the back of the car, it stays dropped forward and gets pen 15ed in the channel.
I popped off the door panel, and this is what I found:
Um, wow. It looks like the window is wobbling around on that vertical shaft or whatever it is called. Some enterprising "mechanic" did a real Mickey Mouse "repair" on the plastic guides? by wrapping a bunch of zipties around them. :shakehead
Is there a better, not to mention cheap, fix for this?
Thanks a lot for any help!
Dave
MOAR ZIPTIEZZZZ!
Just kidding. I don't have an answer, I just wanted to say that.
CoogarXR : 1985 Cougar XR-7
Uh Uh
You mean you gotta buy the whole regulator; you can't get the little plastic guide/bushings/whatever they are called? I don't think so, but thanks for the link.
No other choice here. YOU NEED A NEW REGULATOR
"Fixed"
There's no problem. I don't have the money, time, or inclination to put a new regulator in it right now.
So, I continued the theme of bailing wire and chewing gum. I got some nylon cable clips at ACE and stuck 'em on there. Lubed everything up and it works great. For now. :evilgrin:
Thanks for the advice, everyone.
Wow!
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
That's Redneck actually.
In the ghetto they just push their power windows up and down by hand after they fail.
When I said "MOAR ZIPTIEZZZ!" I was kidding ;) Oh well, whatever works!
Quote from: B-17 Dave;413868
That's how Washington is handling things too.
Hey, you gotta do what you gotta do sometimes. Is there a how-to on replacing the regulator here, for future reference?
