Topic: 86 SVO Spendals (Read 1441 times) previous topic - next topic
86 SVO Spendals
Is there a difference between the 86 svo and my 87 tc spendals?
87 TC
86 SVO Spendals
SVO spindles were sourced from the Lincolns and they are both different than the 87-93 Mustang 5.0 spindles which are identical to the 87-88 TC spindles.  MM has some good info on them here:
http://www.maximummotorsports.com/store/index.php?main_page=tech_front_susp_svo_spindle
Darren
86 SVO Spendals
Basically I have received a full pullout 86 svo spendals, rotors, and brakes I want to use the rotors for my 5 lug swap and as I already have the svo master installed (bad choice for stock brake setup) will I be able to keep my stock spendals and use the svo rotors and brakes.
87 TC
86 SVO Spendals
Wish I could be some help ...... I got some frankinsatng break set up and I'm still trying to figure out the details
It has 11" breaks off a saleen witch are the same as svo but its still 4 lug
86 SVO Spendals
Yes. The rotors are commonly used on the GT and TC spindles. The SVO calipers will also boot right up.
Darren
