Topic: Brakes have failed, mech cant help (Read 15831 times) previous topic - next topic
So my brakes pedal is completely stiff. I wont press down at all. Both of my brakes light are on in the dash. What could be wrong? Boost or master or something else?
my mech said that it isnt a standard vacuum brake system, it has more electronics because of ABS and he doesn't have the machines to check why the 2 brake lights were on in the dash. He said that new ones are pricey... bad day for me...
Ok so your booster assembly is shot or has an electrical issue. Better start checking the circuit. Sounds like you have a wiring problem. Most likely the power relay. Time to get out the test light. The system is electric. You have no power assist. The system is DOWN. If the unit is shot better convert it. Or i have a working unit in a car i am converting. Or i am sure someone has a good used unit. But better start troubleshooting!!
MOST LIKELY THE RELAY. Or possibly the ignition switch!!!
Pump relay or fuse link S. Check this first !!!
:hick::mullet:
I dont know anything about the wiring. Where is the power relay, pump relay and fuse link? I had a bad windshield leak on the driver side, it wouldnt surprise me if that caused this problem.
Not real familiar with the setup, but the Relays should be in the fold down tray in the trunk, behind the rear seat, and next to the ABS Computer. If it ends up being worse case scenario, and you need another ABS unit, I will let my 88 TC's piece go for cheap. It still works perfectly, I just don't need it anymore as I am converting over to Vac-Assist.
I have the whole vacuum assist setup for the swap if you're interested,  just throwing it out there.
Thank you all for the help. Is a vacuum setup just as good?
Chuck W. That helped me out alot. One question. I dont understand this line, " Use a heavy gauge jumper wire to jumper the T/Y and GY/R wires in the socket. The pump motor should run."
I am using jumpers cables to start just the plastic relay box?
A heavy gauge wire for that jumper would be something like a #10 wire... #12 and maybe #14 would likely be OK, but no smaller...
Probably 9 times out of 10 the pump motor relay is at fault...
No... Something like a 12ga or 10ga wire. Jumper wire does not mean jumper cables.
I've done the swap on both of my 88 TC's and had no problems.  Ditch the abs its nothing but trouble
How hard is the swap? I have no specialty tools.
Why don't you just see what the issue is with the ABS before you think about swapping systems?
I agree with Chuck, could be as simple as a relay or accumulator ball.
