Topic: another v6 to v8 swap. (Read 2907 times) previous topic - next topic
I just bought a 1987 v-6 with good clean body. Underside has no ses(minus the fron air dam) and only small damage from a wreck on the drivers side fender. It wasent repaired all that good, but a new fender and it would be pretty perfect. Now the problem. Now I know what all of you v-6 guys are complaining about. Driving the v-6 on the free way the way I would my v-8 I am only getting about 15 to 18 mpg.
    Anyways, I have one too many for the driveway now. I have a couple of "go fast" parts. I also have the 86 in my avitar that has many problems with the body flexing and just quite a few misc things. I am becomeing fond of the 87 body. Basically what do I need? I have the wring harness and motor mounts and a complete 86 sefi v-8 with almost everything for the H.O. conversion. Basically I am just trying to see if ya'll think it ill be worth it.
Re: another v6 to v8 swap.
I would pull the dash and change its harness  as well.  The 86 engine harness will not plug into the 87 dash harness.  Are the clusters the same type, probably both base clusters?  If so it will make it easier.  I'm not so sure if the 86 mounts will work?  Somebody else?
Oh and why wouldn't this be worth it?
Well I think it will, I know the motor mounts will work, If they dont I will make them. I am just looking for a second opinion. 86 has full digital 87 has the base. I think I will pull the dash and get the harnesses switched out. Its just that I need to get rid of this other car. I have been meaning to for almost a year that it wasent running, but now that it is I am not sure I want to. I need to get rid of it though. Its just that I want to make sure that It is taken care of after I get rid of it. The v-6 might just go back in the 86 for a destruction derby. As sad as that is, it has major physical damage. Needs a new rear quarter panel and the frame is warping and the alignment needs fixed. Maybe even a whole new front end. Interior is pretty much shot as well. I dont want to get rid of it, but the time has come. Thanks for the input.
I say forget about pulling the dash...can't you just whip together some adaptors using the interior harness of the 86 and the engine harness of the 87?
Quote from: joefriday
I agree with Joe, no way I'm rippin out a dash harness on one of these things..  heater core is hard enough...
eh I guess. First I need to make sure that it is legal to throw in a 5.0
Quote from: Haystack
Usually the law states you cannot install a engine that is older than the body... But If you tell 'em it came from a '88 who's gonna know???
My 5.0 is a '86, and have plans to build a 347 in a '85 block...
