Topic: Where is the second connector/pin for OBD? (Read 3619 times) previous topic - next topic
I'm pretty sure I asked something like this long ago, but I can't find the thread. Once again I cannot find the second wire/single pin that is used when attaching a code reader to run KOER tests. Where does the wire come out of? I thought it might be hiding in some wire loom, but I cannot find it.
1988 Thunderbird Sport
Mine is on the driver's side by near the brake booster. Both the big 6 pin connector and the 1 pin connector are right next to each other on the same harness.
Yeah, I don't know where my second connector is.
Hmm I'd check mine but it's at the shop getting some trans issues worked out right now. If I remember correctly both of the plugs come out of the harness in the same spot. The second plug didn't get cut off at some point by accident did it?
I remember a thread about this. Turned out the Self Test input (W/R) was in the six pin connector with the other three wires instead of being a one wire pigtail.
The other wires:
Tan/LG Fuel pump relay.
Y/BK Self Test output.
BK/W Signal Return
Quote from: softtouch;413218
I remember a thread about this. Turned out the Signal Return wire (BK/W) was in the six pin connector with the other three wires instead of being a one wire pigtail.
The other wires:
W/R Self Test input
I had that revelation in bed this morning and curious if the other connector was sitting inside the larger one, but they all seem attached. I remember MANY years ago when I purchased the code reader that there was a separate wire/connector, but I do not see anything like it now. I seem to have 5 wires in the larger connector?
Quote from: Seek;413219
Is that cable harness from something newer than 88?
I screwed up!! It is the Self Test Input wire W/R that is the single wire connector.
I found this connector arrangement that I saved about a year ago.
It is supposed to be the "International" version of the connector and shows the STI (self test input) in the 6 pin connector.
Do you know if your car was built for export?
isn't that connector just a ground?
There is nothing in there. I'm pretty sure I used to connect a separate wire to the code reader long ago, but I don't see anything of the sort now. The Brown and Yellow/Black both go to the same pin. The rest are obvious where they go I think. It looks like I have fuel pump, signal return, self test out, and whatever the pin is opposite the fuel pump.
Looking for this answer too. I just tried to read the codes today with a cheap scanner and had no single wire to connect.
1988 Thunderbird
5.0 HO, t5, TC rear, TC brakes, etc. - Gone
Sti
The Y/BK and the Tan wire in the same connector pin is correct. This is Self Test Out and the tan wire goes to the check engine light.
The White/Red wire is the Self Test In. Unplug it from the 6 pin connector and hook it to the single wire on the code reader.
So, were you able to get your code reader to work?
