Topic: stock boost gauge vacuum tube. (Read 1351 times) previous topic - next topic
So the line that comes off the stock intercooler (black with orange stripes) and at the vacuum treee there is a T-connection that goes to the vacuum tree and the other side goes into the firewall, is that the stock boost gauge line?
So what line is that for?
its the line to the boost gauge in the dash, I capped off all of the other lines on the I/C and turbo and had no issues.  the only line I kept on the turbo was for the wastegate.
The line you are referring to with the T is most likely for the cruise control.
Brian Leavitt
86 TC 5-Speed -- MS2x w/COP | 83lb. Injectors| T3/T4 50 Trim Stage 3 .63AR | Full 3" Exhaust - No Cat | Motorsport FMIC | Ranger Roller |
------------------------Ported E6 | Walbro 255HP | Kirban | Pierburg EBCV @ 20psi | BOV | 120-amp 3G | K&N Cone | 8.8" 3.55 rear |
87 TC 5-Speed -- Cone Filter | Bypassed BCS | Stock Daily Driver
66 Mustang -- Pertronix Ignition Upgrade | Slow-Mobile
