Topic: 88 tbird washer sprayer motor location? (Read 1414 times) previous topic - next topic
So I have to check out my wiper washer sprayer motor.  It's on a 88 tbird and im thinking it's behind the driver side tire?
88 Turbo Coupe 5 Speed..Full exhaust, K and N, Boost Controller
Quote from: 88turbo;412441
its located in the bottom of the washer tank.
Thanks under the hood or behind the driver side tire?
much much easier to take off the whole fender,, honestly it is.  you will be staring at the washer bottle in 30min tops.
turn your wheel all the way to the left or right before you start so a stubby phillups can be used to remove the phillups screws on the fender skirt.
Raise up the body slightly to get to the fender skirt screws along the top middle section of the fender well.
remove two or three phillups screws along the forward part of the fender well.
remove 1 phillups screw directly underneath your driver door.
use a socket / wratchet for all the bolts.... it honestly takes very little time at all.
