Topic: Oil level sensor (Read 3053 times) previous topic - next topic
Oil level sensor
when I was doing the 5.0 swap in my 88 TC I never found a wire for the oil level sender.  I know that I could add the wire, but does anyone know the color code for the wire in the 5.0 harness?  or has anyone ran into this issue before?  I would really like to make the low oil light functional again.
Oil level sensor
On my 5.0 LX the wire is on the driver side near the shock tower (where the coil is). I believe it is near the wiring for the oil pressure gauge.
Oil level sensor
I remember it being pink with a blue stripe. I can check for you when I go out to work on the car tonight.
Oil level sensor
The 87 EVTM shows a dark blue/light green wire from the sender to connector C2001.
And a dark blue/light green wire from C2001 to the relay.
The 88 EVTM shows a dark blue/light green wire from the sender to connector C2001.
And a white/pink wire from C2001 to the relay.
C2001--LH fender apr0n near dash panel. Gray 1 terminal connector.
Oil level sensor
gimmie a call later , 304 772 3411, ill be pokin around on the wifes ghia and i can check to color for you.
if you have it, it should be a single wire with a "pinch on/off" type connector.  i was just staring at this sucker last weekend on my sons bird..... didnt think to get the color.
Oil level sensor
I've found a white with pink wire coming out of the dash harness,  how would I go about testing to see if this is the right wire? keep in mind that my engine is not ready to start quite yet.
Scott, I will try to remember to give you a call next time I get a chance to go out there.
Oil level sensor
If you ground it, the light will go off.
It was either orange or pink with a light blue stripe on my 87 bird.
Oil level sensor
Quote from: Haystack;412637
It's the other way around. Grounding it with the key on, turns the light on.
Oil level sensor
On my old car woth digi dash, grounding stopped the annoying beep of the oil guage. buttstuffog must be different.
