Topic: Air pump/smog pump question (Read 3560 times) previous topic - next topic
On the late 80s 302 efi engines they have an air pump on the passenger side being driven by the serpentine belt. This pump probably creates a lot of drag so is there a way to pull it out? Like putting a smaller belt on or does some aftermarket brand sell a eliminator for it? Or should I just leave it be instead of going through that hassle?
Buy smog pump eliminator for 5.0 its the same part used but mustang owners they have on Ebaysummit jegs  etc. then all you have to sure is plug off air pump lines for back side of heads and exhaust.
Should I just cap them off?
You can cap the air tube or plug the back of the heads if you remove the tube
Alright so I can leave the tube in I just have to cap
It off. I'm sure that I'll gain a few HO from eliminating that  thing
It dose not rob much power it's just pushing air but yea even know I'm in ca smog  is the first to go for me lol
I've heard that smog delete can cause cat cloging. A long pry bar can fix that.
Never heard that but I like the way you think lol
You can bypass the belt without removing the smog pump, just get a shorter belt. The smog pump is almost just a pulley to begin with. I don't get why people buy the eliminators.
What about the tubing going from the exhaust to the pump? There are wires connected to it and I think they are sensors
I eliminated mine, and bought a shorter serp belt.  I also have a offroad H pipe w/out cats.
Mike
I dont have cats either so i dont have to worry about clogging anything in the system. If i eliminate the pump does the car recognize that it has been taken out?
I would suggest that you get the plugs that go in the back of the heads as this will allow you to remove the tube assembly and get you more room to work on that side of the car.  The wires that you said you are seeing going down to the exhaust could be for the O2 sensors so definitely figure out what those are before you go removing them.  Cut the tube going from the O2 pump the the exhaust about 3" to 4" from the exhaust pipe and cap it.  If you can weld it shut that is better.  I took mine out of the car and had an exhaust shop weld it shut.  They would not do it here with it on the car as it qualified as emissions modification which could get them in trouble.  I completely respected their position on it and asked if I could pull the X-Pipe out and bring it to them and he was totally cool with that.
Darren
I gutted my pump. Just broke the plastic blades off. All that remains is the housing,pulley and bearing. I had bought a air pump eliminator pulley, but it didn't fit. The pulley was the wrong size. The gutted pump worked perfect as a pump eliminator. As Aerocoupe said, after that, you can plug the back of the heads and eliminate the tube assembly.
