Topic: step on brake and front marker lights come on! **SOLVED** (Read 14542 times) previous topic - next topic
ever since i purchased the 20th several years ago, the random "Lamp out" yellow lense would illuminate randomly but then go away.
a week ago it came on and didnt extinguish like it usually had done in the past.
to save a lengthy thread about what all the unbelievable additional symptoms are happening, here is what i have isolated down as what i feel could be the root abnormality.
1
with no keys in, if i simply go sit in the drivers seat and depress the brake, the front outter marker (yellow) lamps come & inner headlamps come on along with the normal rear lamps.
2
additionally what i have noticed is when i am in a left turn mode, the illumination on the right side bulbs strobe in sync with the left lamps.
3 my chime module is chiming very low now much lower than it usually does.
Item 1 i believe is causing all the other odd things happening id rather not list unless someone is interested, i just think they are all rabbit holes that lead nowhere when i see one fault that could correct the situaton.
I am going to stew through my EVTM but wanted someone else to see if they could find a common denominator as well.
By "inner headlight" I am guessing you mean the parking light.
Page 92
No ground on the four brake/parking lights.
When you step on the brake the current feeds back through the parking light, through fuse 15 and through the front parking lights to ground.
the lamps on either side of the grille, they come on along with the left/right front turn bulbs when i step on the brakes.
for this issue, i was starting to think the multifunction switch is hosed up on the inside somehow especially since its a **Huge** problem when i activate the left turn signal.
humm,, im "almost" confussed,, second attemp on page92 of the 87evtm tomorrow.  page 92 is "without" lamp out warning but the gray box says "with lamp out warning".
i was looking at page 95.
basically i know that no bulbs should ever come on up front when i step on the brake pedal.
Quote from: jcassity;410914
  Yes there is some mislabeling. Page 92 has the resistance wires for the lamp-out feature. Page 89 is the without lamp-out feature diagram.
Does this help?
From what you describe you have a ground issue i would think. Remember the multi function switch also controls the stop lights when you are making a turn they double as signals. What i usually do is test the lamps with a test light to ground and operate the lamps with the issues. Touch the side of the lamp casing with your test light probe. If it comes on dim or flashes ETC you have a bad ground easily repaired at the source. Sounds like you are back feeding looking for a ground. Easy to trouble shoot with a test lamp. You know the old fashioned one not a LED or electronic one. Back test the grounds and you will find it. I THINK???
I have dug in pretty deep, getting nowhere but the problem is not critical.  I have a VW in the garage under daily TLC for 2 months of afternoons now which is taking all my time.
so... one of the thing i mentioned earlier i said i would not get into may be important...a symptom so to speak.
~with headlamps off, if i press on the brake pedal my marker lamps on either side of the grill light up *but* in additon my instrumentation relay de-energizes so my dash goes dead.
~with headlamps off, with *no* brake applied,  if i do just a turn signal to the left, the flasher and cluster indicator strobe & clicks very very quickly
~with my headlamp switch moved to the marker or headlamp lamp position, if i depress the brake, the instrumentation relay is not effected so the cluster stays on.
~with my headlamps on, with *no* brake applied,  if i do just a turn signal to the left, the flasher and cluster indicator strobe & clicks very very quickly
I think my car is telling me there is a "Lamp out" for a good reason.(car does not have system sentry, just the one bulb on the lower left of the cluster).  It appears i have the left side of my instrument cluster going dim or it goes completely dark intermittantly.  If i have a bulb out in the dash, this might be the cause,, just speculating although no diagrams indicate the "full" digital cluster is observing "all" lamps.  The diagrams indicate that the rear lamps are only monitored but all rear lamps are good.
i have not performed the missing ground test yet, no excuses here, just letting you know time has not been on my side.
Personally, my first step was to do a safe back out of my relay mod for IGN & ACCY slave relays and also back  out of the headlamp mod and position all the wiring as original to make sure my mod is not "finally" the cause of the problem.  It is a reality i have to consider.
the only lamps that are actually out in my "full digital cluster" are the bulbs that are lighting up my left side of my dash.. they seem to have progressed from intermittant to partially lite up in the past few days.  Im betting that if i repair this part, perhaps the issue will be solved but again, the diagrams dont say that.
Quote from: TOM Renzo;411342
Understood,
I am mostly having trouble understanding where in the circuit to start because i cant seem to layout where the brake switch can feed the lamps that are coming on ***UP FRONT***.
my first gut instinct was telling me i have a faulty multifunction switch with an internal failure.
i feel like a troll now though,, i havent even checked for a blown fuse... need to do that today.
Time to DIG IN JAY!!!
Quote from: jcassity;411365
Understood,
I guess the diagram I posted in post #7 is not very clear.
The brake light current goes through the brake element of the dual element bulb, then through the parking light element of the same bulb. From there it goes through the elements of the front parking light bulbs to ground.
your diagram is clear, i knew where you were going earlier.  Its just that under this condition as you have it sketched out, both elements should be on during the fault, this is not the case.  also the condition is only during a left hand turn.
Just one or both tail light bulbs on the left side not grounded would cause the brakes to turn on all the front parking lights.
Also it would cause the left turn to flash all the front parking lights.
You are right, it would cause both elements in the ungrounded bulb or bulbs to light up.
I thought you said in your original post that stepping on the brake also caused the problem to show up.
If you would pull the left side tail light bulbs out and and still have the problem, that would let me stop thinking about them and go on to something else.
as of now the left side of my instrument cluster illumination is completly out... dark except for my beng able to barely make out the data displayed for fuel, temp ect.
***********since the left side of the instrument cluster illumination finally went totally dark, all symptoms disappeared with this malfunction and the only thing that still remains is the left side of my cluster illumnation is dark~~!!!!!!!!  what a problem here eh?
Im thinking ill just replace the cluster illumination bulbs and montior it.  talk aobut a jacked up problem!
yes, stepping on the brake caused my front inside only lamps to come on with no headlamps picked which is how i concluded this must be the root fault, and finding out how this is possible without illuminating other bulbs is kicking my butt.  car 100% stock except for Ign/Accy slave relays and a headlamp mod using the auto lamp relays to work front / marker lights.
-causes my rear lamps to light up like normal
-causes my front lamps on either side of the grille to come on steady
-causes my instrument cluster illumination to go dark
steping on the brake with marker and / or  headlamps selected:
-instrumentation cluster illumination stays on as normal.
-during L turn condition with no brake, with no lights, the turn flasher makes a quick irratic fast switching noise, left rear lamps flash but right lamps appear strobe a little, instrumentation cluster remains on, front inside lamps remain off
-during L turn condition with brake, with no lights picked,  the turn flasher makes a quick irratic fast switching noise, left rear lamps flash but right lamps appear to strobe a little, instrumentation cluster will switch on and off in opposite reacton to the left turn signal arrow shown on the dash, front inside lamps will come on and flash.
-during L turn condition with no brake, with lights, the turn flasher makes a quick irratic fast switching noise, left rear lamps flash but right lamps appear strobe a little, instrumentation cluster remains on, front inside lamps remain off
-during L turn condition with brake, with lights picked,  the turn flasher makes a quick irratic fast switching noise, left rear lamps flash but right lamps appear to strobe a little, instrumentation cluster remains on, front inside lights do not flash but remain on.
