Topic: BlkBrd is breathing a little easier now! (Read 1189 times) previous topic - next topic
When I bought my TC (BLKBRD) a couple of years ago it had a 3" crack that ran along the top of the cast-iron turbo exhaust elbow. Since the car already had a 3" down-pipe, and 2 1/2" dual catless exhaust to the rear bumper I wanted to do a more complete breathing fix when I repaired it.
I had a 3" steel tubing elbow fabricated and then a mechanic friend who is also a fabricator installed it.  He cut pieces from a mandrel bent U and made two 45º bend pipes and used a flex pipe from Stinger to complete the installation. Below are the pics of the process:
Steel elbow & new oxygen sensor installed
Flex pipe & first 45º piece installed
Buttoned up tight with the second 45º piece & a Stinger Clamp
Speed is just a question of MONEY How fast can you go?    (M. M.)
Looks nice.  Should flow pretty good.
Mike
Thats a good fab and should work just fine!!
For those interested, that IHI down elbow is a new build unit, not built using an old elbow. New laser cut , and aluminized mandrel bent elbow. Fabrication included the proper cut for the additional material to allow the flow from the wastegate port to enter the main tube. I wish I had remembered to take pics before I shipped it.
John, if I had known you wanted pics of it I could have snapped them prior to installation. It is a beautiful piece of work.......thanks
Ron
