Topic: Auto dim failing (Read 3977 times) previous topic - next topic
Auto dim failing
My auto dim brights have been acting up for a while, and now its gotten worse.  It went from not dimming, or dimming and not coming back on, to now flashing the brights at oncoming traffic.  Anybody know if its the switch, or the sensor behind the mirror, that's faulty?
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 3.8 V6 - Rescue
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 5.0 V8 - Survivor
Auto dim failing
I had to fix this same problem in my '88 Bird. The sensor behind the mirror controls the auto-dim.
Disconnect the electrical connector going into the sensor behind the mirror. Get a paper clip and jump pins 1&4 (first and last pin in the connector). If everything works normal again, then the Auto-Dim sensor is faulty. Replace it and all will be well again.
Auto dim failing
sometimes, it works perfectly fine...even to the point where it will keep the lights off if there's another car in the close distance, to avoid turning them on and then off again quickly...but other times they will turn right off and ill have to play with the dial to get them back on, or they wont dim at all and ill have to do it manually.  On rare occasions, like the other day, they'll flash frantically; once was at oncoming traffic, the other was when i was turning a corner under a streetlamp.
Auto dim failing
Classic Auto-Dim flakyness. Replace the sensor, or bypass it like I said earlier, by disconnecting the harness, and jumping pins 1&4. If the Auto-Lamp sensor was going out, your lights would flash completely off and on, and not just flash dim to bright. The auto-dim sensor is easy to replace, takes all of 3 minutes.
Auto dim failing
I don't even use it.  My 88 has it, but I learned 10 years ago when i had my 87 that AutoDim was just unusable.  Try driving through town at night after the lights switch to flashing yellow.
Auto dim failing
I actually missed the second portion to your post earlier lol.  Im not electrical savvy, what would connecting the 2 pins do?  If the wire wasnt plugged into the sensor, wouldnt the auto dim not work at all?
Auto dim failing
No, but that is the point here though. Once you bypass the sensor and everything works again, albeit manually, you know for a fact that the sensor is at fault, and not the auto-dim/lamp control or multifunction switch itself. If you just unplug the electrical connector to the AD sensor without jumping pins 1&4 then your brights won't stay engaged anymore, once you jump the pins your brights will work again manually (controlled thorough the MF switch lever on the column, like always). You can keep it like this and control your brights yourself, or buy a new sensor and install it if you like the auto-dim feature. I really didn't need it, and choose to delete it from my bird, along with auto-lamp.
Auto dim failing
Ok, ill try that.  I was thinking it may have been something wrong with the switch, as in the sensitivity adjustment wasn't working, because sometimes I could fix the problem by rolling the sensitivity back and forth.
Auto dim failing
It's a known issue, and is pretty much always the sensor with these cars. In fact I'd bet 10:1 it's the sensor. I've fixed many in 80's Mark VII's, Versailles, Cats, and Birds at the resto shop I work in on the weekends. Anytime one comes in with that problem, I know automatically to throw an AD sensor at it. Works Every Time.
Auto dim failing
Quote from: TheFoeYouKnow;409528
thats too funny,,
so what does a flashing yellow and flashing red mean???????  (see tysons corner northern virginia in the wee hours of the morning)
The officer asked me that question and my response was "broke"
he kinda looked at me and asked me where i was from and what my lights look like down there in West Virginia,,
I said there are none...  he said get out of here,,, just be warned a flashing yellow and flashing red means to "stop with caution",,,  I almost pissed him off when i looked him dead straight faced and asked "but how else do you execute a proper stop, would the opposite mean skidding to a stop?"
Auto dim failing
I didn't think anyone actually used that option. I never use mine since whenever I drive by a new (reflective) road sign my own headlights would set it off.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Auto dim failing
I almost never use my brights.
When I did pizza delivery, I used the autolamp functiom because I would sometimes forget to turn off my headlamps. Eventally, I got so annoyed with the lights turning on under overpasses and people telling me I left my headlights on, that I just turned it off and forgot about it.
Auto dim failing
Quote from: Quietleaf;409659
I've had that happen with mine. Really sucks when driving down a dark road. I use autolamp all the time though. The autodim? Not so much.
