Topic: Headliner and console question (Read 1779 times) previous topic - next topic
Are the headliners interchangeable between the 87-88 T-Bird and the Cougar. And does anyone know of a console that can be used in a 88 T-Bird.I know I would have to remove the one that hold the window and seat switches.I like the full lenth consoles.Trying to create my own look.
Al Green:cool:
As far as the headliner, I have no idea. My console came from an '86 Thunderbird. It's full length from the dash to the back seat. I like that. The shorter consoles look incomplete to me. My car is an '88.
No, the headliner won't interchange, but Vinnie is spot-on about the console.
You can use any year cat or bird "fox" style console. 87+88 are the shorter ones. You will need the radio surround and brackets from one to. if you find one in the yard.
I'm just thinking....you may be able to use a cougar headliner in a bird, and cut it down..... maybe?
I don't know what a bird headliner really looks like compared to the cougars
Quote from: daminc;408552
I think your thinking backward, us cat guy's got a shorter roof, It's usually just the material sagging, Redo it. It's not that hard to pull the whole thing, I did it on my 83 a long time ago.
No, he's thinking semi-correct...the T-Bird headliners are shorter than a Cougar. In theory a Cougar headliner could be cut down for a 'Bird. But for 1987-88, with molded headliners, that still might not work...I don't know. Never tried it myself, always recovered what was in there instead of trying to make something else work.
if I remember correctly...the bird headliner I pulled out of the 87 parts bird had 2 weird seams near the rear window, and 2 push in clips to hold it in...
my cougar has neither of those, but as Eric said..in theory it might work....
I was at the yard friday getting part and looked inside a 87 Cougar.It looked like it might work but then it may need to cut.I will continue for a T-Bird.
Al Green:cool:
Its just that I want to leave the one in the car until I can redo one.The yard sell then for 15 bucks ,they just don,t have one now.I have the fabric to (red),but want bto be able to swap it out when it done.I have seem videos on youtube.I can do the.
Al Green:cool:
