Topic: Hood spring problem (Read 2397 times) previous topic - next topic
Hood spring problem
Quote from: STANG8U;408092
Well to swap hinges you have to remove the fenders and that's a job avoided buy just using a prop
Ummmm...no.
Hood spring problem
Is there a trick ?
I tried to remove a set and they were hung up in the fender like there was a bolt inside the fender area
Hood spring problem
i cant speak to it, i cant remember, i recall there being an underhanded sneaky clippidy do thingy that is made on the hinge and it hooks into a slot then  you add bolts.
i do know the hinges come off without fender work though, ive only had them off once ever and that was in like 2003.
Hood spring problem
They come off without moving the fender,there's 3 bolts, one is hidden by a rubber trim piece.
Hood spring problem
No need to remove the fender. Thanks for the support guys. SUPPORT??? THAT IS THE ISSUE AT HAND!!! Just kidding the rod mod is a good one cheap and dirty and if it works for you that's great, Good idea. BUT the broom stick from the wicked witch will also suffice for hood PROPPING. Just me i am nuts anyway!!!
Hood spring problem
It's a ez fix and it bolts right to the car who can go wrong with that lol
I did not chop anything up and I can put springs on later down the road
But there has to be a trick to remove those hinges I took all the bolts out and there was a part of the hinge stuck in the fender
Hood spring problem
Quote from: jcassity;408096
i think the answer is yes , to your quote but my pic points to the adjuster
Yep that's what I was talking about.
