Topic: More Horsepower! (Read 12941 times) previous topic - next topic
More Horsepower!
That is exactly what I needed to confirm that I received the wrong replacement elbow for my TC.
Thanks a bunch Tom
Ron
Speed is just a question of MONEY How fast can you go?    (M. M.)
More Horsepower!
:DDANG! did that little thing come off of a riding law mower???!!!!LOL
Quote from: TOM Renzo;408799
Here you go. The back side of an IHI!!!
Donnie
10 Second NA TBird
Fredericksburg Va
More Horsepower!
Quote from: grey88smokin;407690
You can pull some timing and it will be more responsive but the less boost you can run before it starts to rattle; that's why I said to be careful. Start at 12* and see how you like it, you can also retard the cam some too to bring the power band down to match the ignition timing. Make sure your searching because there are other factors that determine how much boost/timing you can run.
Retard the cam to bring the power band DOWN??????????????????
Retarding a cam with everything equal increases the upper end HP
Advancing a cam with everything equal increases the bottom end HP
More Horsepower!
Did somebody send u the T3 elbow?  T3 with a .63 is a great turbo.
You really don't have the fuel to really use it, unless super crank the fuel pressure.
Travis
More Horsepower!
Quote from: TOM Renzo;408931
I said that?! I did...Im sorry I had a senior moment
More Horsepower!
No Worries Grey88 It happens to me all the time. My brain is in limbo some days also. No sweat Thanks.
More Horsepower!
Quote from: 87 T-BIRD;408858
It was on my granddaughter's little red wagon!
LOL
More Horsepower!
Quote from: turbotrav;408949
Travis
Hey TRavis,
Sorry it has taken so long to answer your question.
I did get the wrong elbow, but it was quickly replaced with the correct IHI elbow for my TC.
I am getting ready to use the custom mandrel bent steel tubing T3 elbow, that was sent by mistake, on my 84 SVO.
Ron
More Horsepower!
Maybe Im a little late getting in on this discussion, but have you swapped to roller lifters and cam out of a Ranger 2.3? I used to race a 4cyl circle track car and we had to run stock stuff so we used a shaved hydraulic D port 4 plug head with the roller cam and lifters from a later model ranger and a lot of timing along with a Holly 500 and a big through the car header on our Pinto.
More Horsepower!
Quote from: Thunder Chicken;407661
I think your biggest problem is no compression on cylinders 5,6,7 and 8 ;)
Agreed
More Horsepower!
Quote Originally Posted by Thunder Chicken View Post
Quote from: hwy73;419699
Agreed
That must be what is causing that whining-whistling sound on my TC also.
Here all this time I thought it had something to do with the turbo???
LOL
Ron
More Horsepower!
I really dont think the absence of 4 cylinders means much. As the 2.3 is pretty stout against some ford engines of bigger displacement. I have had many 5.0 guys scratching there head when i POP the hood of a 4 BANGER after smoking them. OUCH!!!!!!!!!!!!!!!
More Horsepower!
Quote from: 88TC4lyfe;407666
lmao yeah yeah but it's lighter! :D
not by much, if any...
86 Mustang GT
More Horsepower!
There has been lots of discussion on the subject of 2.3T weight vs 5.0 weight on various forums over the years. The general consensus seems to be about 100lbs when both are factory stock.
That may not sound like a lot, but I remember getting real happy if I eliminated 15 or 20lbs back when I was drag racing my 65 GTO.
It especially counts when the weight loss is up front.
I can't seem to find it right now, but there was a thread on 4eye forum where someone had converted to an 84 SVO to a 5.0. He said that he was surprised at how much handling capability he lost with the approximately 3.5% weight gain up front when he installed the 5.0.
Ron
More Horsepower!
i'd like to see proof of this, as in both engines on a scale.
I have both here, but don't have a scale big enough to weigh them. i'm guessing he was using cast iron intake and exhaust manifolds on that 5.0. the turbo manifold/turbo is ridiculously heavy. the blocks are nearly the same size with the 2.3 being taller, but narrower and the 5.0 being shorter, but wider. 5.0 has one less head and the 2.3 head seems to be larger than a 5.0 head as well.
86 Mustang GT
