Topic: Back in the yard (Read 1708 times) previous topic - next topic
Back in the yard
Finally found a tilt column to fit my car but had to go through the back of the dash to get every wire and connector to make sure I had everything. Took all of the trim and cluster out in one piece for the next guy to come along.;)
Back in the yard
was that woodgrain dash in good shape?
Back in the yard
Are you looking for one Jerry?
Back in the yard
Dash was perfect, that is why I took it out in one piece. It also had the digital cluster in it, if you look to right in the second pic its on the seat. This car even had the ignition key that is why I messed with it.
Back in the yard
Can you grab the front license plate holder, please?
If the car is there when I go back saturday I'll grab it if it is still there.
Back in the yard
You should grab the dash as well. An uncracked dash is REALLY hard to find these days.
Back in the yard
Looking at the first pic..that dash looks shaged up to me. Just below and to the left of where the column was is bent the hell out.
Back in the yard
Any chance you could grab the grille?
Back in the yard
@ThunderbirdSport302. The plastic dash came out in one piece. The parts that are bent back are metal frames that held the trim. I was chasing wires most people would not be as delicate.
Back in the yard
Quote from: vinnietbird;406323
one of mine is faded near the drivers window
also looking for the center woodgrain part too...for a center console car
