Topic: What is this? (Read 1350 times) previous topic - next topic
What is this?
New to 2.3 turbos what is this ?
What is this?
That is what controls the boost. You need to connect vacuum hoses from the turbo and wastegate up to it.
What is this?
Unless you've done so already, go aftermarket.
What is this?
Yea the car has a boost controller
Cool thanks guys
What is this?
IF im not wrong... thats also the annoying little thing that sets off the overboost buzzer if you turn up the boost
What is this?
Also my stock boost gauge dose not work dose it have something to do with that if not where is that sender
What is this?
well check your vacuum hoses. It should come off your intercooler. Its black with orange stripes. It runs along the firewall and under the vacuum tree. See if that is hooked up still.
