Topic: Quick help - T3 wastegate snap ring (Read 1348 times) previous topic - next topic
Hi guys,
I need a quick help. Can someone measure inner size of the snap ring, which holds the wastegate actuator rod on the wastegate lever? I can't measure it with the engine in a car. It's missing on my silver bird :(.
Thanks
these clips work really well for the wastegate linkage I found mine on a chevy truck in the junkyard but you can get them from advance part no. 118-080
Thanks, but I can't get these anywhere easily in the Europe.
I've found the part number using google and it is 1/8". Is it the inner size, or the size of the shaft? I'm a bit worry, that I will be able to buy only snap rings in metric sizes. 1/8" is just a bit over 3 mm, so I will give it a try :).
sorry about that forgot to check your location, good luck with the search.
