Topic: Relay bank mod COMPLETE for IGN switch, Headlamp and Marker lamps (Read 5161 times) previous topic - next topic
Good info, thanks for the update!
Oh, hey. FYI I buy these by the 10's.
http://www.ebay.com/itm/10-PACK-12V-12-Volt-30-40A-Automotive-Relay-Socket-30-amp-40-amp-relay-/290610422473?pt=US_Relays_Sensors&hash=item43a9bb22c9
One caveat though, the relays don't always last in the underhood environment. I found you need a better relay if they are to see moisture at all. So, I get Bosch relays to install in those cases.
They gang together nicely, and the plugs are of decent quality for the money. Inside the cabin, no issues on longevity.
I'm a satisfied and repeat customer of theirs.
Quote from: TOM Renzo;406173
Jay if memory serves me i think the 5 pr0ngs i sent you were the type you can remove the spade female connector??? I do it all the time. Look inside and use a tiny flat blade screwdriver to release the connector. Thy have heavier ones as well. I talked to my vendor and he said they were rated at 25Amps
What Tom said. I remove and/or move around the wires all the time. Just release the locking clip with a tiny screwdriver and pop them out. Then re-use in a different spot if need be.
