Topic: Protecting Things!! (Read 1606 times) previous topic - next topic
Protecting Things!!
Well with the new Fluactic Generators on cars fluids must be absolutely clean. So here is a cheap mod to keep your wiper squirters free from junk. I install this lawn mower filter to the feed line off the washer pump before the squirters. Just me by now you guys know how  NUTS I AM!!!
Protecting Things!!
My Sport has a filter on the washer hose....not sure if it's factory or not, but there's one on there.
Protecting Things!!
a lot of fords had them from the factory, looks like a vacuum check valve.
Brian J Larkin
1988 Tbird Turbo Coupe
1989 Cougar XR7
1995  Ranger Splash
Protecting Things!!
Well i figure for a BUCK it served the purpose and has very good surface area. We use them and they work very well.
Protecting Things!!
HA~!!!
great idea ,, solves a complicated problem with a simple solution.
Protecting Things!!
Thanks JAY
Protecting Things!!
That fluid doesnt look blue?
Mike
Protecting Things!!
It is not it is the stuff that does not Freeze. So it is Gold in color.
