Topic: My 88 TC (Read 11878 times) previous topic - next topic
My 88 TC
Yea it will be painted white to much work and money to change colors the right way
Plus I like the white .....TC's are Oxford right ?
My 88 TC
Yep, pretty sure it's factory name was Oxford. At least it was on the Mark VII's.
My 88 TC
Yea and the white fox mustangs
My 88 TC
I liked the last pic so much I took another today after grabbing a pack of smokes
I also through on a new fuel filter unplugged the knock sensor and turned the boost up from 10 to 15 and it likes it night and day difference ..... Still dose not feel fast to me though lol
I'm going to swap on the bigs and littles on the 10th and see what she dose in the 1/8th stay tuned
My 88 TC
Nice looking car!!
My 88 TC
Thanks I just hope I can get around to doing this valve cover gasket so I can run it down the strip
My 88 TC
Car has Ben sitting due to needing a smog but I did a few things today
Changed the vc gasket ..... Wonder why it was leaking uhh .. Some people should not touch cars
Also changed the plugs ..... I knew it was blowing out the spark
Look what some asshat did
Wrong plugs and way over gapped
Smog soon so I can drive this bitch again hope she will pass the legal way lol
My 88 TC
Well new CA star program sucks
Did a pre test today passed smog by 1 point but fail visual
Those dumb ass toutched my car now I have a check light and I failed .... Never had one till he dicked around
My trunk and car fill up with gas fumes now also .... This is turning into a big deal thank you California
My 88 TC
Well got some gauges on a trade so I thought I would put them in I still need the matching water and boost
Took for ever to get the stock sender out there is no  room lol
My 88 TC
Nice. I'm gonna be mounting my gauges in the same place, when I get ready to install gauges. Already have my boost gauge mounted in the hole where the stock clock used to be, and yea that stock oil pressure sender and the fitting, is a royal bitch to get out of there in that tight space. I waited until I had the head off on mine, and then took a 4ft long prybar to it, lol.
My 88 TC
Yea getting it out sucked lol and it's a perfect spot for some gauges
My 88 TC
Ok I have a very badly cracked bell housing
Found one in the yard but it was also cracked
Is this common on 2.3 turbos ?
Anyway dose anyone have one they can ship to ca for cheap ?
Just shopping around for the best deal work is tight and I need one on the cheap
My 88 TC
No one has a bell sitting around ?
My 88 TC
You looking for an A4LD or T-5 bell?
I'll see what I can find this weekend at the JY.
My 88 TC
T5 with a  hydraulic set up
I need cheap though I was hoping someone had one lying around
