Topic: WTB: Driveshaft transmission ending for Turbo Coupe with automatics (Read 721 times) previous topic - next topic
Hi, I'm looking for driveshaft transmission ending. We're still solving the problem of the lost driveshaft. I can get a AOD cougar driveshaft, but it has biger transmission ending, so I need the ending for Turbo Coupe with automatic tranny. My car has C3 tranny, but the A4LD should have the same size of the output shaft.
The ending should have these dimensions - outer diameter is 35,0 mm (1 3/8") - that's exact - and inner diameter is aprox. 28 mm (1,1"). This number isn't exact at all, but since you can't measure the output shaft, it's the only number you can measure inside.
Thanks.
