Topic: power seats (Read 1560 times) previous topic - next topic
power seats
Morning Guys,
  got me a new 88 TC,  driver side power seat doesn't work. Any one have a good wiring diagram or some suggestions?? I checked power at the switch and there was none!! fuse is good, i gotta figure it out so i can move the seat back(i am a little taller than the original owner)
Thanks, Joe
power seats
Is the switch itself bad?
power seats
flipnbird, When you say your not getting voltage, did you check the wiring before and after the switch (turned on) for voltage? Just stick a pin in the wires and take a reading. If you have it before and not after, you found your problem. I always take the seat and window motors apart on my older cars and service them. Good luck!
power seats
I actually just probed my meter right at the switch. Can I just put a pin in any of the wires before the switch to see if there is power?
power seats
in my signature there are a couple of links to wiring diagram books.
the 1987evtm link should match up, however i have not yet uploaded my son's 88evtm, again the diagram on page 181 should match up.
here is a link to an older thread showing the power seat diagram,, just look at the color of the wire from the source circuit breaker and check for power on that color wire at the switch.
Qualifier-- do you have "memory seats",, two buttons on your door arm rest?
http://www.foxtbirdcougarforums.com/showthread.php?16213-Duel-Powering-seating-mod..
power seats
Quote from: flipnbird;403822
just ground your black meter lead or test light
prob any wire coming into the switch but like said, the circuit breaker has a wire that feeds the switch per the diagram.
once you verify you have power coming in, it spreads out across different directions depending on the poistion you place the switch.
They do come apart and you "could" inspect but its up to you.
