Topic: V8 vs. V6 fuel pump (Read 4107 times) previous topic - next topic
V8 vs. V6 fuel pump
Quote from: Fordracer08;403528
This is another item I wanted to ask about so when the time comes to do the swap I am prepared. i just wanted to be sure that a bigger pump can be swapped onto the factory hanger. It will be an HO 5.0 so the least it will have is a 190lph pump. I will keep an eye out for Mustang guys selling their unwanted parts. I am not keen on the parts store pumps either. The reliability is not the best.
Hey Vinnie, lets see a picture of your access panel to the fuel pump in the Sport. I worked at a couple of import dealers over the years and a lot of their cars have access panels to get to the fuel pumps. Makes it a lot easier.
Thanks for the input everyone.
The pump will fit the factory hanger fine, might have to use zip ties, might not. I think the access panel was an idea that was sped by ford if you go in your trunk and feel on the carpet on the passenger side there is a hump and that is directly over the fuel pump. Cut that out and put in a latch system and you got yourself an access panel that in my opinion seemed like it should have been there from the factory.
V8 vs. V6 fuel pump
The pump in the T-bird/Cougar has a larger diameter than the Mustang/Mark VII pump. Aftermarket pumps are the same diameter as the Mustang. When I bought my 155lph Walbro I was able to purchase it with a rubber sleeve that fit the T-bird pump bracket. Unfortunately I don't remember where I got it from. A new pump will bounce around in the stock T-bird rubber sleeve as it is a thinner diameter than the stock T-bird pump.
V8 vs. V6 fuel pump
Have you heard of worm clamps!!! That is how i mount most of these pumps. Tie raps are a very bad IDEA. I will see if i have some photos of my PUMP MODS!!!
I do not have to many photos of pump mods. But here i am retro fitting a fuel pump from an early S10 Blazer to fit a SAAB. The SAAB pump is obsolete and the replacement unit is TELEPHONE NUMBERS. So here is a chevy pump in a late model SAAB. Worked great
V8 vs. V6 fuel pump
Tom, if I were the owner of said Saab, I'd upgrade too...the vehicle, that is. LMAO.
Yeah, zip ties in a solvent? Not such a good idea. Of course, most are polyethylene, so they may hold, but I'd use a clamp if need be.
V8 vs. V6 fuel pump
I would probably use the worm clamp too. I wouldn't have to worry about them coming loose or falling apart. Interesting to know the Mustang and T-Bird had different size pumps.
Hey Tom, I bet that Saab gives you plenty of business. LOL!
86 T-Bird V6 C5
91 F-150 5.0L 5spd
93 Mustang LX 351C C4
2013 Honda CRV AWD
V8 vs. V6 fuel pump
YOU BET. Between coil packs at 400.00 each and 7 UP DATES . Mass Air flow meters and whatever you can shake a stick at. You have to have ROCKS IN YOUR HEAD WHEN A CRANK SENSOR CODE REQUIRES CHANGING SPARK PLUGS!!!! The car is a piece of . But it is a money MAGNET FOR US!!!
V8 vs. V6 fuel pump
OK FOE how about this one.
V8 vs. V6 fuel pump
Saab: Job security.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
V8 vs. V6 fuel pump
Quote from: TOM Renzo;403580
Around here, we raise bigger field mice than that, lol.
J/k, he'd do alright for some taco meat and some steaks ;)
V8 vs. V6 fuel pump
I know i am waiting for the BIG ONE.
V8 vs. V6 fuel pump
Quote from: thunderjet302;403558
The turbo coupes use the smaller pump like 5.0 Stang, even has same numbers on them...
V8 vs. V6 fuel pump
255 and call it a DAY!!!!
V8 vs. V6 fuel pump
Quote from: TurboCoupe50;403613
Hmm I did not know that. Thanks for letting me know. Now I wonder why Ford would go through the trouble of using two different pump sizes.....
V8 vs. V6 fuel pump
The pump I swapped in came with a new rubber mount that fit perfect in the stock hanger assembly. No hose clamps involved (minus the small short hose to the line).
