Topic: Fox and SN95 parts. Stock & performance (Read 1102 times) previous topic - next topic
Updated, organized, and more parts listed
Exterior Parts:
-1995 Cobra shell, no motor, trans, rear, front suspension, no front clip, doors, bumpers, decklid. Missing most of the interior. Good foundation for a racecar or use for parts to fix another stang. No title $300 very negotiable
-87-93 cheese grater taillights, emerald green $100
-87-93 lx noses. Red, white. $50 each SOLD
-87-93 hatchback 1/4 glass. 2 sets, decent shape $50pr
-79-93 notchback rear glass $60
-83-93 mustang convertible top side tensioners. New. $10
-A #pair of foxbody ford racing alteeza taillights $40
-Foxbody wiper arms $10pr
-79thru82 cowl grill. $40
-87thru93 cowl grill. One small crack $10
-87thru93 Vermillion red (code ep) hood with insulation and light $75 SOLD
-84thru86 GT 1/4 molding $25pr
-35th anniversary fender badges new NOS in bags $30pr
-White DS fender extension (pn F1ZB-16A169-AA) $25
Interior:
-2 tilt columns with keys (foxbody) $30 each
-1994-1995 Svt Cobra instrument cluster $250
-Blue 87-93 console shell. $20
-2 pod gauge housing (replaces clock) $20 SOLD
-Gray tweed hatchback rear seats 87-89 $35
-1992 V8 dash frame with wiring $35
-Blue console armrest $15
-2 5spd shifter inserts (87-93) $10 each
-87thru89 HVAC surround w/bezel $15
-Blue fuse panel cover $5
-79-93 Shifter boot $10
-Blue glove box $5
-Red glove box $5
-79thru86 headlight  $10
-2 87thru93 top&hazard switches $5 ea
-87thru89 smoke gray headliner. Non sunroof $90
-2 87thru93 ebrake console rubbers $5 ea
-87thru89 smoke gray kickpanels $15pr
-Blue map light $5
-5spd accelerator pedal $10
-PS a-pillar trim $5
-Fox hood release w/ cable $10
Engine:
-Comp Cam XE274HR light usage $130
-Polished aluminum valve covers (tall) $50 2 sets
-CAT 1.7 3/8 Roller tipped rockers. New in box. $100
-Felpro Permatorque MLS 4.6 2v head gaskets. New $60 for the pair
-Edelbrock #victor jr carb intake, tmoss ported $150
-Fox oil pan $30
-Edelbrock performer 5.0 intake with 1" phenolic spacer $300
-Comp cams nitrous cam 609 lift 114 centerline $185
-Edelbrock performer 1" spacer $25
-Brand new in box smog pump delete kit with polished bracket $50
-Used smog pump delete $25
-24lb #injectors, new o rings & pintle caps $100
-C&L flow tube for 24lb injectors $20
-Comp Cams polymer upper intake for a stock 5.0 lower $80
-Accel afterburner switchable coil ( with wiring, switch, and relay) $25
-Fox egr spacer with egr valve and throttle bracket $25
-2 sets, stock HO valve covers $20pr
-3/8" phenolic spacer for a HO intake $15
-NIB Canton windage tray PN 20-960 $30
-Stock roller lifters $25 (16)
-2 alternator brackets $20 ea
-Fox air silencer $5
-3 HO valve cover to throttlebody hoses $10ea
-75thru78 Mustang II PS V8 motormount. Frame section $50
-BBK off-road h pipe for long tubes with power pipes and Mac lers (all welded unit) $175
Drivetrain:
-Steeda multihook clutch quadrant. $30
-Mustang II V8 flexplate. $40
-Kirban short throw shifter for a 3550 trans $75
-Hurst Competition Plus shifter handle w/ perfect 95 cobra shifter  $50
-8.8 rear w/ 3.08 gears $100
-2 foxbody speedo cables. Original Ford $25ea
-23t white speedo gear $10
-2.73 gears w/ good trac-loc unit $50 SOLD
-94thru95 V8 5Spd driveshaft. May fit other years $25
-Solid trans mount. Fits T-5, AOD, C4. $20
Wiring Harnesses:
-1992 Mustang GT mass air harness. No computer $125
-1992 Mustang taillight harness $30
-3 5spd wiring harnesses. Kickpanel to trans $50ea
-88 mustang V8 dash harness $35
-88 mustang headlight harness $15
-Automatic wiring. Kickpanel to trans $30
Suspension, wheels, tires:
-A set of turbine rims, no caps. Very nice. $100
-17" 5lug 95 cobra spare tire $75
-Lakewood rear drag springs. One coil cut $75
-Lakewood rear 50/50 shocks. Need new lower bushings $35
-Used quad shocks $20pr
Miscellaneous parts, cables manuals, etc:
-87-93 fan shroud. New. $50
-Fox/SN tank cover $10
-V8 fox radiator brackets $20pr
-1995 Mustang owners manual w/case. Complete $25
-1998 Svt Contour owners manual with case $30
-2 a/c evaporator canisters with line $20 ea
-2 V8 fox throttle cables $30ea
-fox tank filler neck $5
-fuelpump hanger w/pump. Walbro 5CA 209. Condition unknown $20
-fueltank float assy $10
-Fox TV cable $25
- 2 factory jacks $10ea
All prices are obo and do not include shipping and 3% paypal fees
Please call, text, or email for more details and pics
484-772-0071
Stangbangin93@yahoo.com
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
