Topic: Somethings wrong. (Read 18047 times) previous topic - next topic
Somethings wrong.
Reply #120
I now have about a 27ga. wire in place now. I will go back and check for voltages. Should I will go and try to start the car now?
Somethings wrong.
Reply #121
27GA is too thin I think. It will burn immediately. But you should try just to turn on the ignition. It may survive the current peak.
This chart is something for you - http://www.powerstream.com/Wire_Size.htm
Somethings wrong.
Reply #122
Ok! Now I have voltage at my injectors, heater blower is working and rear defroster is working. I still see no voltage at pin #1 pin has no voltage, #20 has 11.93v., #47 and #57 nothing. The 27 ga. held up fine.
Somethings wrong.
Reply #123
Pretty sure I heard the fuel pump, but it still won't start.
Somethings wrong.
Reply #124
I went out to the car and found out that I forgot to hook up the coil wire to the distributor cap. I tried it and it started right up. Right now it's idling pretty smooth. The 27ga. is still hanging in there!
Somethings wrong.
Reply #125
Quote from: 86cougar;402825
Ok, now you have located the source of your trouble, now replace the defective fusible link with the correct fusible link and call it a day.  I would be extremely wary of shorts beyond the fusible link, because they don't typically fail without a significant fault.  The blow slower than a fuse or circuit breaker, so that would indicate to me that the cause is not a short term arc or transient short, but something long enough term that without the benefit of the fusible link, your wiring harness would melt and potentially cause a fire.
Somethings wrong.
Reply #126
Good job. Don't forget to swap that fuse link to correct value to be sure you won't stall somewhere because of burnt under rated fuse link.
I can't believe, that it took so long time. They were asking you so many questions but nobody told you "Try this and this".
Pin number 1 should have constant power from battery. That's the only thing you should check, where is the problem.
Wait a second. What color is the wire connected to pin 20? It should be the orange wire connected to the ground. Are you sure with 12V there?
Somethings wrong.
Reply #127
All the gauges are working. So, it looks like everything is working so far. I do have an exhaust leak on the passenger side. A small pipe that should mount about where the passenger's feet are. That's where both left and right side of the exhaust connect. I need to get that pipe back in where it belongs.
Somethings wrong.
Reply #128
I think all I did was check if for ground. It is B/O color. No exhaust leak, just fluids burning of my exhaust.
Somethings wrong.
Reply #130
The cars idles fine, but once I give it gas it stammers. That's what it was doing right before the fuse link blew. My guess is I need a new EEC. Does that sound right to you guy's?
Somethings wrong.
Reply #132
5.0 engine and I put in a new MSG distributor about a month ago.
Somethings wrong.
Reply #133
I went and moved the distributor over a tooth and I had to turn the distributor over a little so I don't know if it's really any different than before. It idled good and revved-up good until it warmed up. I have no idea where the timing is at, but I did notice that if I moved the distributor over it started sending smoke out my exhaust.
Somethings wrong.
Reply #134
I am loosing my mind here seems like someone was not listening to good. As i predicted this trouble in the first post. Now someone actually gave you advice as i did many days ago.
My post #7
    If you blew a fuse link you have something grounding out. Try disconnecting and separating them and back feed the links.
BACK FEED THE LINKS WHEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I am loosing my mind. D'OH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Help me DEAR GOD I AM GOING NUTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
