Topic: Somethings wrong. (Read 18177 times) previous topic - next topic
Somethings wrong.
Reply #105
Yes, I have light and voltage coming from the coil pos. wire.
Somethings wrong.
Reply #106
Tom, I need a schematic to know where all those pins are on my EEC connector. Otherwise, I will only be guessing.
Somethings wrong.
Reply #107
I guess I still need to check the TFI on my distributor?
Somethings wrong.
Reply #109
Trinom,
          I got it thanks! What is UTFG? Use the f%^$# guide? According to this schematic, what I tested was not pin #1, but pin #20. It did have an B/O wire going to it.
Somethings wrong.
Reply #111
I just tested pin #1 with key and nothing. When I check for ground are you wanting me to test "continuity"?
Somethings wrong.
Reply #113
Tom, I do not see a female on connector #37, and there is no power at #57.
Somethings wrong.
Reply #114
This doesn't look right, I have no female pin at #60 and no continuity at #40. Iknow when I called the store for another EEC, they said there was more than one and I needed to get it matched up. Calif. and non-calif..
Somethings wrong.
Reply #116
Trinom,
          I still have the original fuse link that blew apart still separated. It is a blue link with 20 ga. and B/O wire. That is what started this thread.
Somethings wrong.
Reply #118
No, but then nobody asked me to and I was checking the  system to find out where I lost power. Should I hook this fuse link back up? Am I taking a chance of frying something else?
Somethings wrong.
Reply #119
I'd recommend you to use a some small fuse to check, that there is no short in the system. I saw many fuses blown for no reason, so I would do this first. Changing a blown fuse is easier, than changing the fuse link. Use some small fuse, I'd recommend you 5 to 10 amps. ECM shouldn't take too high current to operate.
