Topic: Rust at bottom of rear window! (Read 5551 times) previous topic - next topic
good work!
Nice job, OP and 347.  I'm going to be tackling this same issue on mine soon.
'83 302/AOD Heritage (silver/red, full restoration w/ SEFI, 5-lug, 8.8, rear discs in-progress)
'95 Explorer Limited (white/gray, 4x2, 323K mile daily driver)
'97 Cobra (black/black, bolt-ons, 4.10's)
'04 Lightning (black/gray, bolt-ons, stock-pulley gas guzzler)
347 what did you use to shape the corner again where the trim goes, you have any finished pics?
I made the metal as close to the shape as I could then I used duraglass, then bondo after I laid trim on top and marked it took off and sanded by hand, on the flat spots I used a block hope this helps
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
