Topic: Rust at bottom of rear window! (Read 5544 times) previous topic - next topic
:mad:  do they make a patch panel for this issue??
XX
they don't make any patch panels for these cars...at least that I ever saw, or found...
your gonna need to cut that out and weld new metal in that section
Like Daminc said..........
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
had the same problem
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
yep.. same place as mine :(
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
thanks for the pics 347, gives me hope
Started the fixing process.
XX
Looking good.  I had the same rust-out, but in a 67 Mustang.  I fixed it the same way, by patching, welding, filling, grinding and finishing.  A LOT of work, but the results were outstanding.
Daniel
347 is that the epoxy primer there in the picture?  I guess you spray epoxy primer first then body filler?
I have the same problem in my 83 TC, I will get to that much further down the road.
Quote from: 83TB;403193
No its self-etching primer, after the repair, I put dura glass over the welds then finish bondo
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Sorry for the swearing but shiznit...this job might cost me an arm and a leg :(
1987 Ford Thunderbird Turbo Coupe ~ STOCK
If they have to pull the rear window, and repair rusted-out sheetmetal, then yea it will be up there.
You pay a certain premium to own an old car, and rust-repair usually part of it.
Do you weld or know someone, I pulled my own window, and had a welder from my farther in law.
the right side did real good I think, my very first time does this body work stuff
X
The left side had a spot that lifted, I sanded the whole back panel under window before laying any body filler or painting any filler primer, but did not do any work right there, i think its from the other body work that was done, a small dote keep popping up so I pushed it in and then the old paint peeled right up.  IDK!
X
