Topic: aftermarket shifter (Read 1187 times) previous topic - next topic
aftermarket shifter
does anyone know  aftermarket shifter they make that will drop right into a 88 tbird with a aod that will allow me to manually shift into to all forward gears.
aftermarket shifter
also does anyone know of a thinner steering shaft that will bolt right into our cars to allow for more room for our headers.
aftermarket shifter
For the steering shaft, check out Maximum Motorsports or Flaming River.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
aftermarket shifter
I think flaming river or unisteer makes a steering shaft with an extra knuckle as well for extra clearance if you are having problems with yours.
aftermarket shifter
I know for ranger's to put in a v8 you can replace the rag joint type steering with ford econovan steering knuckle, supposed to be smaller.
