Topic: oil pump shaft (Read 1760 times) previous topic - next topic
oil pump shaft
Would it make a difference if I were to take the retainer ring of the shaft and drop it in from the top (distributor hole)?
oil pump shaft
DON'T DO IT!  If you miss the pump, that "tinkle" you hear will be your invitation to pull the pan.
oil pump shaft
Actually, the pan is already off. I still have to remove the rack and pinion in order to get the pan to drop enough. Also, in order to drop my rack and pinion, I have to take my end links off the anti-sway bar so I can remove the bolts from my rack and pinion so it will drop. Then I still need to disconnect my pick up tube bolts so my pump will drop enough so I can push the shaft upward. If the shaft misses and drops in the pan no big deal, I just get it and try again.
oil pump shaft
Reason #2.  If you don't install the retainer ring, you run the risk of doing the same thing when you remove the dist for any reason after the engine is assembled. Sometimes the shaft will come out with the dist and then fall when the dist is just about out......ask me how I know.
oil pump shaft
Quickshift,
              Now that make sense to me! I already dropped my rack and pinion, and moved my anti-sway bar so the bolts for the R&P are out. I found my original pump shaft, it was in there just not where it should be ( I know... newbe). I still need to drop my pick up tube so I have room to put the shaft where it should be. I better get back to work before it gets dark. Thanks!
oil pump shaft
Well, the shaft was in there, just not in the small hole. It was in the opening right next to it. I didn't know it could do that. I figured (A) hole, only one opening....wrong. Well I can see it from above, so IF it stays there all I have to do is put it all back together. Live and learn.
oil pump shaft
Quote from: QUICKSHIFT;399892
For real.
oil pump shaft
I've done it on a '78 Fairmont that wrung the shaft off, as long as the shaft falls into the pan there's no problem...
Pump was locked on that Fairmont, I just turned it backwards and a piece of valve stem seal puked out the oil filter adapter... With a fresh shaft she was off and running, fix(if you can call it that) took maybe 15 minutes...
oil pump shaft
I took the distributor and put it in place, then pulled it out just make make sure all was well. Shaft stayed right where it is supposed to. The pump is in place and tightened down. Tomorrow I will put the pan back on and fill it with oil then spin the pump. My cheap oil gauge has a transparent line, so I will be able to see if I'm getting oil pressure.
oil pump shaft
can get away without the retainer,
stuff the pump shaft up into a 12'' or longer vac hose just a little.
aim down in the hole, rotate the pump shaft till it drops into the oil pump, then rotate the vac line off the top of the oil pump shaft.
most times than not, the oil pump shaft will stay stuck up in the dizzy when extracting the dizzy for some reason in the future.
oil pump shaft
you are right, i agree but when you extract a dizzy and find the shaft on the end of the dizzy, whats a man suppose to do?
i am curious about this topic anyway, something small to discuss but yet interesting in that on my 20th, the motor has not been extracted as far as i know but yet my oil pump shaft came out with the dizzy,,, like the factory did not put it in.  what are the odds ?
oil pump shaft
Quote from: jcassity;400045
What you did, would be a cold day in a extreme southern region before I'd pull the pan to install the retainer, if the shaft falls in the pan just install another... As long a it has oil pressure, I'm surely not loosing any sleep over it...
oil pump shaft
??????????????????? Where did the factory clip go!!!!!! Why is it missing from the shaft???
:hick::hick:
oil pump shaft
Tom,
        Read the first question on this thread and you will see that I still have the retainer on both the original and store bought shafts. I put the new one in with the retainer in from the bottom like it should be, I did not drop it in from the top. Today, I try to start my car again. I need prayers!
