Topic: Anti Slosh Module? (Read 6092 times) previous topic - next topic
Anti Slosh Module?
the buttstuffog senders are still common and out there.
any bird/coug with full buttstuffog or buttstuffog with digi speedo will work.
you do not want the sender that came from a car with "FULL" digital everything from rpm, fuel speed temp ect.
im still a little confussed on your source for the sender but either way, you now know the issue.
when the time comes, i would like to buy your obscure sender,, been wanting one to experiment with per an older post to wire it for either set up.
daminc has a lot of experience disecting them as well.
Anti Slosh Module?
I got this sender from Latemodelreso.  It's for Fox Stangs.  When the time comes, I'd ship it to you for $40 if you want it.
I'll check around and see if I cantons a good used one out of a parts car then.  Thanks again for your help'
William
