Topic: I'm stumped! (Read 2877 times) previous topic - next topic
I'm stumped!
^^^ This!
I'm stumped!
That's exactly what I did. Even the four corners of the valley gap, I took my finger and wiped off any access. There won't be any in my ports, I made sure of that. I took my time with the steel wool and made sure the surfaces looked nice, then I took the manifold and washed it out real good with a hose and nozzle then let it dry. Yep, it probably took me longer than some, but at least when I was done I knew I had done a good job of it. Tomorrow will tell.
I'm stumped!
I can't tell you how many vehicles that weren't wrecked, that DID have silicone or permatex oozed out from between intake and heads. Some of which have been 5.0 engines.
Needless to say, if you need an engine, and find one with silicone in those spots, keep looking because it's probably got serious issues.
I'm stumped!
Were the heads cut down, or is it a new intake?
Its common to have to mill down surfaces to keep a flush seal.
I'm stumped!
The only time RTV is ever a problem is when you get people using it who don't know what their doing, and end up gobbing half the tube around a water jacket, which then squishes into the ports once they tighten things down. Use it sparingly and you will never have that problem.
