Topic: 86 bird taillights in a 84? (Read 1173 times) previous topic - next topic
will 86 Tbird taillights fit in a 84? the 86 have chrome strips on the bottom and my 84 bird tails do not.
Quote from: stockbutfun;399094
They should fit in with no mods......
If the T-Birds are like the Cougars, there's a different taillight metal mounting panel back there, along with a different wiring harness. It's not likely to be a direct fit...tpuppies and modifying are likely...
Quote from: EricCoolCats;399134
Eric is correct.....this is what i recall....
'83-'84 - Reverse lamp in center of taillights.
'85-'86 - Reverse lamp on inner edge of taillights.
83-84 lights are identical except for ornamentation. 83-84 Cougar lights will fit exactly as will 85-86 T-bird and Cougar lights. They all use the same mounting, just like the different styles of Mustang lights from 79-93.
so to use the 86 lights I just need to switch the reverse light location is what I'm getting. thank you
