Topic: Rear Quater patch panles (Read 1265 times) previous topic - next topic
If any one can help Im looking for rear quater patch panles.For left and right side for a 1984 brid.
I may be able to come up with some.  I think the cougar lower body line should be the same.
As far as I know, there are no aftermarket patch panels available.  Instead, you will need to locate a syard 'bird and salvage panels from that. These are getting harder and harder to find though, so you might have better luck finding an almost "driver" locally, liberating it of it's panels and then parting out the remainder.
if your creative and good with a welder, you can use sections of front fender around the wheelwells. and sheetmetal for the rest.... good luck on your search
If you think you have some let me know?
