Topic: drive shaft (Read 2893 times) previous topic - next topic
drive shaft
I have a parts car with a v6, can I keep the drive shaft, I am going to use a v8 with c4 or t5?
drive shaft
what did the parts car have behind the v6?
drive shaft
i will check i am guessing right now and say its a stock v6 and tranny set up.
drive shaft
C-5 is what is in it
drive shaft
I have made a decesion to use a 302 or 351w with a 5 speed, where can I buy a aluminum drive shaft for it?
drive shaft
Do a search and you will come up with several threads on how to get one made from a Crown Vic and other cars for cheap.  Vinnie for one has done this with good success.
Darren
drive shaft
I did use the crown vic drive shaft and had it cut down and balance, use with 351w T5 and nine inch rearend
drive shaft
DON'T mismeasure the driveshaft and have to get it retubed.  $118 shortening and $345 to make it the right length again.
drive shaft
I measured like three times, it fits real good
