Topic: Performance Power steering pump (Read 1576 times) previous topic - next topic
has anybody tried one of these before? I know it looks nothing like the one i have because my reservoir Isnt attached to the pump but it says its for a thunderbird 2.3.
Got a link? or pic?
A pump with attach res will swap in. That bracket was in way of something when I was messing with my bird and I swapped to a 90 mustang pump.
If it ain't broke, it doesn't need fixin'.
I doubt you'll get more than a horse or two from a so-called performance pump. May as well just swap in a manual rack, if you want anything of the sort.
Keep the stocker, unless it's going out, then I'd replace it with another stock pump. Leave the chinese shiznit on the shelf. ;)
My pump is starting to go out now so im just looking at options. If this one doesnt work, Im going to just buy one from ford.
http://www.summitracing.com/parts/AGR-808102/Application/?query=Year%7c1987%7cMake%7cFORD%7cModel%7cTHUNDERBIRD%7cEngine+Size%7c2.3L%2f140
SR71, go to AGR's website http://www.agrperformance.com. They're not Chinese junk.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
