Topic: car audio help??? (Read 2911 times) previous topic - next topic
car audio help???
Hey guys I have a few problems with my current setup, first MAJOR problem engine noise coming from the amps, second I want to get the car to sound a little better. I have a pioneer deck running pioneer 3.5's, 6.5's and 6x9's, I also have 1 JL audio 10" with a 500w alpine amp, I keep hearing about component speakers, and crossovers, I don't know  it that department so I'm willing to learn, so let me have it.I am looking to buy this amp(Alpine MRP-F300) but should I get a 6 channel amp or just drop two of the front speakers.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
car audio help???
oh and not looking to break the bank with some crazy $500 amp as u can see my audio stuff is lower quality but the car only gets driven once or twice a week, but I like to rock out when I do drive it.lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
car audio help???
When you say engine noise, I assume you mean the whine that increases in frequency parallel to the engine RPM.  To get rid of the engine noise, or at least minimize it, you need to make sure that your source line voltage is filtered, grounds are clean and all lines both into and out of the amp(s) are shielded.  You may also reduce some noise by using shielded spark and coil cables. Of all of these, the most important are the filtering input voltages for both head unit and the amps, followed by clean grounds. Ensuring you have clean chassis grounds is something you can easily tackle without much in the way of cost.
car audio help???
Yes the rev makes it worse,Where do I need the noise filters, on the power to the head unit and the remote wire or the 2 gauge power wire to the amp.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
car audio help???
so I solved all my problems I just bought good rca's and that got rid of the noise, and I went with the 4 channel alpine hooked the 4 speakers to the front jack and the 2 6x9's to the rear and its more then enough when the car is not running but with it running I have to turn-it-up!!!!! loud car
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
car audio help???
If you have the fender mounted antenna connected to the head unit then do not connect the ground wire from the head unit to a chassis ground.  Leave it unhooked and the antenna will ground the head unit.  Connecting both will give you a ground loop which can contribute to the alternator whine.
Good RCA cables will also do the trick but we never connected the ground on the head unit unless it would not turn on.
Darren
car audio help???
Yeah mine wont turn on without it
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
